defcon.klaxon
Hey guys,
I'm working on creating a PID loop that will modulate a valve on a water filter, and the idea is to close the valve until the flow through the filter matches a setpoint. I just realized that if the flow is too low, it'll require the PID loop to close the valve, not open it so it'll be a reverse not direct output. However, I don't see any way to do a reverse control on the PIDA block. Does anyone have a suggestion on how to create this sort of control loop?
