PID and Motor select
Sep 2019
Fresno
Good afternoon,
I am trying to write code that can select between a PID and just triggering an on/off state on the same output. The output would be on an analog O:1.1
I am trying to switch from a NC Binary Data file to a NO Binary data file that jumps to the PID. So basically when I want PID control I switch to NO when I want just a high state without PID I switch back to NC Binary. This would be for a selector switch.
Am I approaching this correctly? And what is the conventional approach to switching output states to and from a PID instruction?
Thank you
-E
I would have the PID control the analog output at all times, and use your digital signal to place the loop in manual with an output of 100% or 0%, this would require two digital signals. one for auto/man and one for open/closed.
I've done something similar to this using MOV instructions to move a value into the Output %, (CV), Set output .SO and MNO (minimum output. This is when like the machine or the process was off and no PID Control was needed. So, you could move a value from 0 to 100% when the PID wasn't needed into the Output %. Be sure to use the .SWM bit from the PID when writing values into the output manually through a MOV. Hope this helps.
@Saultgeorge and Ken moore
Great, that did work. I used PD9:0/AM to trigger the Auto/Man
and adjusted the percentage. I'm working in Rslogix 500. I used the move instruction to transfer the high value to the output.
Any equivalent .SWM bit or .SO? Im not seeing those bits.
Im reading that there can be a bumby transition if those bits aren't used..
Hey man, sorry. I didn't realize you were using 500. I haven't worked much with that, only 5000 V. 20.04 and Studio. One can click help on the PID instruction or go over it in instruction help. If I had 500 on my machine I'd help you look for it. I know there's some pros here that have it and are quite proficient with it. Also you could do a search in the forum. Hope this helps.
Team, I have a micro 1400 and a 1024 encoder using HSC function to control a 0-10Vdc DC Drive (1/3 Hp Motor) for a simple material take up...
2,345
Hi, we are using DeltaV Dcs. We have problem with Motorized damper, we have motorized damper, But position feedback ( 0 - 100%)is there. How to...
1,897
Hello, I'm student from Malaysian and currently doing a final year project about PID controller design for servo motor by using PLC. If you dont...
19
7,913
Hai friends I want to write a PLC program to control an wire extruder based on PID algorithm. I have a PLC with PID in it. I have configured the...
7,056
Hai friends, I want to connect my PLC to motor drive. I am using EZ touch PLC. I wrote program to control the speed. The process variable is...
4,412
