How to retain the encoder value in FM351 channel DB after warm restart
snraops
Feb 2007
Bangalore
Hi All,
I am using FM351 to measure encoder value. But after warm restart the actual encoder count value in channel DB (DBD26) is getting reset. Is there any method to retain the this value? I tried storing this value in another DB and transfer to channel DB using OB100. But I am not able to write any data to channel DB. Can anybody help please......
You can't write directly to the db. You have to do it with job.
Link to manual.
"9.5 Set Actual Value / Cancel Set Actual Value
Definition
With the “set actual value” job, you assign a new coordinate to the current encoder
reading. The working range is projected to a different physical range on the axis.
You can calculate the offset of the working range as follows: ACTnew –ACTcurrent.
• ACTnew is the new specified value
• ACTcurrent is the actual value at the time of execution"
How to retain Values in CCW software? I am using CCW software and I can not find the Retain function in this software. Not even local or global...
169
In a data block, if the tag is ticked in the "Retain" column", is it meant to be retained after cycling the power to the PLC? I'm finding that...
735
The PLC in question is a S7-1212C. The PLC will be transportable on a wheeled trolley and used wherever it's needed in the factory. I've been...
1,333
I've got a bunch of tags in my code & there's a column called "Retain" (by default they were all un-ticked) - see pic. "LaserN mm" is a distance...
1,595
Hi All, Hoping the community here can help as I'm new to PLC programming. The project I'm working on is using a Micro850 2080-LC50-24QBB and...
1,684
