AustralIan
Did you leave the encoder set to 200ppr?
Also possible that it was a lucky capture. If you have 1mm window and you're skipping every 8.6mm, then what, like 12% chance of getting it anyway?
It seems you have all the math now. Start from scratch with the math ad make sure you are programming and configuring everything to ensure you don't miss. Maybe program in error handling code for when you do miss the window, for example comms loss for 10ms.
