Rs485 to ml1500 tester
bh307
Mar 2008
HOUSTON
57
Does anyone know a fast way to make a rs485 test using ML1500
I have a new trident on a boiler and I am sending date to my honeywell tdc 3000 using RS485 .What I would like to do is hookup A ML1500 to receive data from the trident to test my trident and my cable before hooking into the DCS. Any ideal on how to do this would be great Thanks :p
Thanks Mickey the modscan work great . It turn out that the DCS FTA card was bad not my trident or cable . Just had to jump threw hoops to make the DCS guys believe there new card was bad. Anyways all is good now.Thanks for your help.
Slightly off topic, but I use a laptop with RS-232 port to monitor communications when I am trying to set up a new serial link. It works with RS-232 or RS-485 just connected to the negative line and ground.
Roy
Hi, Seeking consultation on an implementation matter, and have a question about Modicon Compact 984 communication through RS485: Three Modicon...
204
i have an device which can support serial (RS485,RS232),CAN protocol . i want to connect it to an existing MIB 1553B bus ,what device will I need...
88
Hi all, I am trying to do Modbus communications via the CB1241 RS485 Communication Board on a Siemens S71200 PLC. I am using a 1215C CPU. After...
238
I'm trying to use a Red Lion Cub counter (Cub5B00) as a counter and give the cub's counts to a Graphite G12 PLC/HMI to display. After about an...
108
Hello, I'm working on a protocol named "BitBus" which use a SDLC protocol for encapsulation. This protocol contains start & End Flag, but when i...
152
