FactoryTalk ME "The parameter is incorrect" prompt
May 2013
Aus
Have a Panelview Plus 7 HMI, tested extensively in simulation/on PC, but now using the actual hardware getting popups on the HMI 'The parameter is incorrect.', and the HMI freezes until power cycled.
I need to collect more info from site on when it happens, on any particular screen etc. - I'm just going off feedback from operators.
But can anyone shed any light on what would trigger this popup?
HMI part number: 2711PT10C22D8S
PLC: 5069L320ER
Thank you
Kind of a shot in the dark here, but I would check your declarations in your parameter file of your FTV application. Perhaps something is pointing incorrectly.
Yes I believe it was related to system time. I had set up to synchronize with PLC clock, however PLC clock hadn't been set (still at 1998).
The issue particularly happened when trying to display the alarm list, which would make sense if related to the clock
Setting the clock then recompiling and downloading program seems to have sorted it
Thanks for your help
Hi Everyone, I am trying to add a constant value (such as a string) into the parameter file. I put the string in " " but it does not work. would...
185
Hi All, I'm currently designing a faceplate for an analog input object, and I'm trying to create an alarm tab with an Alarm and Event Summary...
439
I will try to explain what I am doing. I have 6 fillers, all of them the same, all of them have 8 heads on each filler. I press a GoTo screen...
1,161
Looking to call a new screen with FactoryTalk ME v12 from the PLC with a remote parameter... FYI the parameter value is an integer 100..199 I...
1,506
