Micrologix 1400, 1 output activated, several outputs closed partially.
AutomationTechBrian
Jul 2013
St. Cloud, MN
669
I was called to help a customer setup a Mitsubishi Servo Drive to a Micrologix 1400. No fieldbus is used, the positioning program is controlled with discrete PLC outputs, with an analog pot for torque limits.
When I got there, the customer had all of the required Drive I/O already wired to random outputs on the Micrologix PLC for a test application. For simplicity, a bunch of them were originally wired to outputs 2 thru 7, which all used the same 24vdc source. He had a test ladder set up to toggle bits tied to the Local outputs. But when he toggled one of the bits, several of the outputs turned on. They didn't show up as being on in the PLC display, or in the online RS Logix, but the Servo Drive showed them as being on. I grabbed my meter and found that the non-activated outputs had 14 vdc... which is evidently enough to be considered "on". I moved several of the wires from outputs 2-7, to other outputs (see pic), and this fixed the problem. We got the Servo test program to work, but now tomorrow we'll look at permanent wiring.
I suspect you guys have seen this before. Is this indicative of a bad PLC, or is there something we're missing in the wiring? I was focused on the servo programming until the end of the day, when we figured out there was a PLC issue. I took this picture just before we left for the day. I noticed that there is a "COM2" or common terminal for that group of outputs. There was nothing wired to it because he said an "example" PLC did not utilize the "COM2" terminal. Is that the issue?
I'm hoping to learn something about this before tomorrow morning. Let me know what you think, please.
Yeah you need to tie COM2 to the relevant "zero volts" of the supply connected to VDC2 terminal.
EDIT: Looks like others beat me to it
Follow up: Yes, the COM2 was the ticket. Looking back, it's obvious. But the seed of doubt crept in when the customer said their "example" didn't wire that output, even though they wired the +24v. However... I found out that none of those outputs were being used, so maybe that was the reason they didn't use them.
Hello, I am using pulse train output to a stepper driver to control a stepper motor. It seems to work fine except when I use a Control Stop...
3,321
Hi. I bought a Micrologix 1400 to run a servo with its high speed output. Problem is that the output is +24VDC and the drive HSI is 0VDC. How can...
1,631
Hello all, I am new to the world of PLC's and have recently purchased a Allen Bradley MicroLogix 1400 (BXB). I figured out that Output Group 0...
3,218
Hi guys, Im currently working on a project that involves cycling pieces manufactured at my work. Almost finished but I started having problems...
2,988
Hey I'm a student working on a project. I trying to control a 0-10V driver using the analog output on the ML 1400. To test and output I've been...
26
9,399
