MVI46-MCM Modbus Comms
Alen bradley
Apr 2013
qatar
23
Hi All,
I am trouble understanding how the Modbus card addresses are configured with respect to slave device addresses.
SLC500 is running the above program with the MVI46-MCM prosoft card in 12th slot. The slave device is a Control Microprocessor with the holding registers from 41001. I am confused as how the holding registers are linked to the M-file addresses in PLC. For example, in the above image, the 41001 holding register is sending data to M1:12.600 which is then copied to N30:0. Where will this transfer of data configured? I have never setup the Modbus comms for SLC500 PLC. Is it done by another program or the sample ladder provided by prosoft for the module? I can not seem to open the sample ladder to have a look in it as the PLC is on different server. I have attached the sample ladder logic from prosoft so if anyone convert it in to pdf so I can have a look, that will be great. Thanks!!
Hello all, We are currently developing a multiphase metering system that will be based on a Micromotion Altus NOC and Allen-Bradley SLC-5/04 PLC...
4,439
Hi I have been tasked with installing a MVI46-MCM into a SLC 500 system. I have never done this before and would like to know how to copy...
2,693
Hello all, I have a problem to go RUN mode for my PLC. I am using 1747-L532E controller. It has turned to major fault (error code = 15Ch) when I...
3,299
Has anyone here attempted to connect Ignition to a SLC with a Prosoft MVI46-DFNT? I am able to do read/writes to the card from a compactlogix but...
1,462
I have some equipment with Allen Bradley SLC 504 PLC's, that have a Prosoft MVI46 ethernet module installed. I would like to configure it to talk...
3,150
