Find an analog input on S7
Logix_Stef
Oct 2014
Havant
85
Morning guys,
I am not very familiar with Siemens S7. I have the Step 7 software and adaptor, I van go online and upload/download a program. So far so good. Now I have come to a situation where I have to monitor an analog input coming from a 4 - 20 mA pressure transducer (see the attached). This is probably for most of you very trival so please forgive me. I can't figure out what address the needed input is. If I did have the address I do not know how to search for the address in the program. Surely, there must be something like the RSLogix data monitor, likely called something else. Could someone pint me to the right direction, please? The transducer is connected to a profibus module, I have never worked with profibus so my knowledge is very limited when it comes to Siemens stuff. Any help would be very appreciated. Thanks.
it says "PEW230". That is the address with german notation.
Your STEP7 is probably with english notation, so you should Look in the cross reference for PIW230.
I am not an expert in Siemens either but try with going to your hardware configuration first
Then identify the right profibus module
when you click on it it will give you the range of address that it is using
Then looking onto the electrical schematic you might figure out the right address
To monitor the value you would need to insert a VAT table it is like a watch table
Then you just need to add the address you want to monitor, save it, download to the PLC and when you go online to it you will be able to see the value (probably raw)
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
126
I have tested every screen and no single screen individually has this fault pop up, but when I compile and send to the PanelView it comes up. If I...
172
Hi, One of my customers has an old fabric tensile testing machine. The IC # AD7501KN of its controller has malfunctioned. This IC is related to...
77
Hello everyone, I am a student and would like to take the next step and learn FactoryTalk (Batch preferably) and how to create HMIs etc. Would...
490
Hi, Have a look at this picture... How can I find out the memory address of this tag? It was created by adding it to DB "Data_block_1", but I...
1,043
