plc storereviewsdownloads
Reply
Thread Tools Display Modes
Old April 5th, 2021, 11:09 AM   #1
Nan
United States
Nan is offline
Siemens S120 Servo Drvie Cylinder Flowrate Control Questions
Hi Everyone,
I am new to siemens servo drives, needs some helps and wondering if you can help me.
The machine has Siemens S120 Servo Drvie and siemens motor, the motor mounted on top of a Cylinder, and move the cylinder up and down, when the cylinder goes up, it sucks material from the tank, when it is going down, it supply flow out, so it controls the flow rate.
Here is some information about the servo setup
The signal-level for the pulses is 5V DC, from the siemens TM 41 modul.
The gear ratio is I: 11,38 , you get 256 pulses per motor revolution.
28980 impulses per liter
I think I can use the formula and PID to control the speed of the servo, and get whatever flowrate I put in there right right?
Grams_per_Impulse = (1/ (IN_HMI_Flow_Meter_Impulses_Per_Liter/ 1000)) *(IN_HMI_Material_Density/1000)
OUT_PID_Grams_per_Second = (IN_Impulses_per_Second*Grams_per_Impulse)/100
Thank you very much!
Old April 7th, 2021, 10:13 PM   #2
Nan
United States
Nan is offline
Anyone have some idea?
Old April 8th, 2021, 02:08 AM   #3
L D[AR2,P#0.0]
United Kingdom
L D[AR2,P#0.0] is offline
As long as you stay inside the torque/power limits of the motor/drive then the drive speed loop controller will maintain the motor speed.
__________________
S7-300 to 1500 conversions done - email to s7conversions@hotmail.com
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Siemens Rotary Servo In Torque Mode JDCROCKETT724 LIVE PLC Questions And Answers 16 January 25th, 2021 07:18 PM
Control Logix Servo Control Amebeo LIVE PLC Questions And Answers 12 February 25th, 2015 06:45 PM
Need Help With SERVO VALVE Control busarider29 LIVE PLC Questions And Answers 6 August 4th, 2014 08:43 AM
Siemens S7 PID Control Problem qee LIVE PLC Questions And Answers 27 May 15th, 2007 11:53 AM
Servo control vomitz LIVE PLC Questions And Answers 4 June 2nd, 2003 11:25 PM
