TIA Portal HMI: Recipe manager and its scroll bar
userxyz
May 2002
any
2,768
I remember from WinCC Flex 2008 that the scroll bar was a pain in the *** on touch screens. But isn't this problem unsolved in Tia Portal ?
Today I used the recipe manager on a TP900 and it seems that the scroll bar is still a small allmost unpossible thingy to control well. I've only seen it in simulation so far, maybe it behaves pretty well when downloaden in a TP900...
Anyone who used the recipe manager on the comfort panels and who can give some feedback about this ? I'm just hoping not te be forced to make an alternative recipe management, only to avoid the scroll bar.
Thanks in advance for your reply,
Kind regards,
Combo
I am working on my first TIA project with PC runtime and I have the same problems as before. It seems like such an easy fix I don't understand why they would not change it or allow us access to a size variable.
If someone has a fix please post it.
Solution
The only solution I see here is the use of 2 buttons: Up and Down.
Events: ScreenObjectPageUp and ScreenObjectPageDown on the Recipe_view object.
Kind regards,
Combo
I've seen the same thing with the Alarmview object. The default scroll bar width was 1 pixel. I found a setting that made it bigger, but it still maxes out at 10 pixels, if I recall, which was still way too small.
I don't understand it either. This should be an easy thing, I can't believe that no one in development noticed that this was a problem. I have fat fingers, sure, but the scroll bar is still smaller than my STYLUS!
Hi guys I after a bit of advice on Tia portal graphics, I would like to add a conveyor belt graphic to a hmi and the conveyor in the basic...
180
hello every one. i'm new to tiaportal, i have created new project and HMI screen the program works fine with PLC-sim, but when i try to cntrol the...
400
My PLC (S7-1200) and HMI (KTP-1200 Basic) has been delivered on-site to the customer. To be able to do "off-line" updates to the code, I am using...
218
...and I agree. Context: TIA Portal/HMI = KTP1200 (12" screen) In the attached redacted image, the values in the white boxes are entered by the...
695
hi everyone. i hope you guys are doing great. i am trying to built communication between aveva intouch hmi 2023 and tia portal v18. i dont have...
560
