TwinCAT 3 Scope view torque units
mhismail
Mar 2016
egypt
30
Hello guys ,
I had a problem two weeks ago with TwinCAT 3 scope view. I have a dc dervo motor from beckhoff AM8011 , with servo drive EL7201 .
I wanted to monitor the torque vs time (YT chart) , everything was very good , I was able to record the Actual torque value by adding it to ADS symbols using drive manager then adding the channel via scope view target browser , I started the motion using NC-Functions then trying to hold the axis of the motor with my hands during motion and watching the torque increases...it all went fine except one thing ...The UNITS !!
The Y axis representing the torque showed values like "1400" ..My question is simple :
What is the unit of "1400" ? It can't be newton*meter or millinewton*meter , since the rated torque of the motor is .20 N.m.
Any help please ?
I think the torque values are in % of motor torque x 10. That is what i have seen from the AX5000 drives.
Well , I too have AX5201 for AM8012C (Torque rated = 0.38 N.m , with gear box i=10 and rated current 1.3 A , peak current 2.6 A)
I tried viewing the torque(Torque feedback value , IDN=S-0-0084) vs time and the scope view gave me values such as 52,68....max=116
so how could these values be % of 0.38 n.m.?
Note: I use me hand while trying to stop the rotor and it never stops just developing friction ).
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
156
Hi! I am trying to run the 'SimpleSample' (https://infosys.beckhoff.com/content/1033/TF5100_TC3_NC_I/Resources/3438746891/.zip ) to understand the...
100
I am developing a library in twincat and one of the function uses IID_ITcVnAccess_TcVnPoint2_DINT and the definition of this type is defined in...
70
Sorry if this has been asked before, and apologies if this seems like a trivial issue, but I am new to Beckhoff and have been banging my head...
148
Hi everyone, This is my first time posting, so please forgive any omissions or mistakes. I am attempting to control the velocity of a stepper...
18
989
