GE Durus program Question
Malador
Jan 2012
Pacific Northwest
60
I can only put 3 inputs on each line before i have to put an output. Is there anyway to continue the instruction on to the next rung? Right now I'm using the "m" internal memory relay to do this, but it seems like there might be a better way.
I apologize if this is an obvious, but I'm new to PLCs.
This is typical of controllers in the "smart relay" category. The GE Durus is a re-badged TECO SG2.
My experience is with the A-B Pico, which has a similar rung platform where only three Input instructions and one Output instruction are allowed. I can't see any method for "rung wrapping" like you can do with virtually all medium and small PLCs.
So you're already on the right track: use an "M" or "N" internal bit to hold the status if your first three instructions, then use the status of that M or N bit as the first element in a new rung.
Hi Ken,
Almost all the smart relays are the same.
you start to hope you don't run out of programming room.
I haven't seen an available memory graph
Dear All I have following Problem. 1)I am using Durus Controller IC210DDR024, I connected Expansion module with it, which is Durus Profibus...
4,905
Hi. I have a 222 CPU. I need to recover the program from the eeprom memory. Is it possible?
78
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
82
158
Posted this to Reddit with little success, so I figured I would share it here as well. Very new to PLCs, but figured I would give it a shot to...
122
