plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old July 6th, 2018, 11:51 AM   #1
lifetech
United States
lifetech is offline
Weintek MT8092XE
Hello
Does anyone know what type of USB cable I would use to connect the PC to the USB port on a Weintek MT8092XE HMI?
Many Thanks
Old July 6th, 2018, 12:07 PM   #2
JordanCClark
United States
JordanCClark is offline
JordanCClark's Avatar
For development? I think it's Ethernet only for that. At least according to the installation sheet.
Otherwise, something like this would take care of the connectivity. After that, though, I couldn't tell you if the host controllers would be able to handle it correctly without other drivers/software.
__________________
_____________________________
Jordan
Any man that can hitch the length and breadth of the Galaxy, rough it, slum it, struggle against terrible odds, win through and still know where his towel is, is clearly a man to be reckoned with.
-- Hitchhiker's Guide to the Galaxy
Old July 6th, 2018, 12:29 PM   #3
lifetech
United States
lifetech is offline
Thanks for the reply... I need to upload the project to make a BU copy and make one slight change... The EB Pro software guide indicated uploads and downloads can be performed ethernet or USB...
I thank you for your reply!
Old July 7th, 2018, 01:03 AM   #4
kalabdel
Canada
kalabdel is offline
I believe the USB is done only with a USB stick not direct connection to PC. The procedure is somewhere out there in one of the manuals.
https://www.google.com/search?q=uplo...utf-8&oe=utf-8
Old July 10th, 2018, 06:50 AM   #5
lifetech
United States
lifetech is offline
Thanks for the reply... I cannot seem to get to the screen on the HMI that allows me to enter the password ...
Also, I would like to find out the IP address of this HMI.. Any suggestions?
Old July 10th, 2018, 08:09 AM   #6
lifetech
United States
lifetech is offline
On power up, there is a system setting icon at the bottom right of the screen...
"When HMI is powered up and displays image, press the
system setting button in the lower-right corner of the screen.
(Default System Password: 111111)
Go to the Network tab, you may choose to auto get DHCP IP,
or designate your own IP.
MT8092XE has two10/100/1000 Base-T Ethernet ports.
The default IP addresses are:" Quoted from the manual....
The system setting icon is not present, only the screen calibrate icon is present. I am able to calibrate the screen, but not get into the system settings to see the IP addresses.
Old July 10th, 2018, 08:18 AM   #7
Mad_Poet
United States
Mad_Poet is offline
Reminds me of our 'Ferag Stacker' machines.
Somewhere in the HMI panel on our machine there is a maintenance
function for copying the parameter set out to a USB stick.
If it's like ours, you might have to contact the machine
manufacturer and ask about how to make a backup
copy of the software. (Mr. Ferag sent me instructions
for buying a little card and a card reader. Put the card
into the machine, copy everything out, put the card into
the reader then copy everything off and stow it on my
laptop, USB stick . . . . Server . . .
Poet.
Old July 10th, 2018, 11:07 AM   #8
cwal61
United States
cwal61 is offline
There is an option to hide the settings bar and use LB-9062 to open the settings bar. If that option was checked in your project by the original designer maybe they added a button to open the settings dialog. Look for a button to open the settings maybe on a maintenance page or something. Also if you have the project file, look for the project name .cmp this is a compressed file that you can use to uncompress and create the project on a new pc. You will find it under Tools
Old July 11th, 2018, 01:47 PM   #9
lifetech
United States
lifetech is offline
Im Back...
I took a stab and got online with it using the default IP address. I then performed an upload, and this process said that it finished. Now, When I open the project it is completly blank. I am using the newest version of EasyBuilder Pro. It almost seems like I need to have a copy of the program
Old July 11th, 2018, 03:18 PM   #10
keithkyll
United States
keithkyll is offline
You need to find the file mt8000. It's an object file containing all of the code and the library objects. Add .exob to it, making it mt8000.exob.
Then, go to Decompile, locate your new object file, and decompile it. You should now have a project. Save it (with your own project name).
I did the above from memory. Follow the steps in this document.
Old July 11th, 2018, 10:47 PM   #11
kalabdel
Canada
kalabdel is offline
Quote:
Originally Posted by lifetech View Post
Im Back...
If you are able to connect then you should be able to download the program I think with .exob extension and decompile in the software. I had the same issue last year and Keith helped me through it.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Weintek Passthrough --> Siemens S7-300 MPI arjenbin LIVE PLC Questions And Answers 3 January 23rd, 2017 07:05 AM
weintek HMI dispay extension buzzymonk LIVE PLC Questions And Answers 2 January 18th, 2016 12:00 PM
Problem connecting Weintek HMI to PLC using Modbus TCP/IP TahirQ LIVE PLC Questions And Answers 6 January 21st, 2014 05:47 AM
Weintek MT8070iH and Maple HMI5070TH wapratesi LIVE PLC Questions And Answers 1 October 26th, 2013 09:58 AM
Weintek HMI and Micrologix 1200 communication ssana168 LIVE PLC Questions And Answers 10 May 20th, 2013 07:25 AM
