Paul_Pereira
So I have a panelview plus 600 hooked to a L33er plc. Plc is 192.168.10.2 and the panelview is 192.168.10.3. I would like to be able to change the IP address of the plc from the runtime application (change both the ip address on the plc and also the plc ip address the HMI should be looking for) which will of course end up in a comms error but then also change the panelview Ip address through the runtime, hence restoring communications. Is there a way to do this?
