plc storereviewsdownloads
Reply
Thread Tools Display Modes
Old February 1st, 2021, 11:13 AM   #1
RockyLeafs
Canada
RockyLeafs is offline
Old Siemens OP7 HMI
We have a customer with a very old piece of equipment (circa 1999).
That has a OP7 Siemens HMI unit. Their current unit has gone down, and are hoping for a replacement.
We have managed to source a refurbished unit, and I have some some files from our servers for the project (.PDB, which we believe might be the file for the HMI).
We typically never deal with Siemens hardware, and never anything this old. This machine was made by our company after we had took ownership.
We've tried to find a contract programmer to be able to connect and download a program to the OP7 unit, but every contractor has stated they are too busy or has not gotten back to us.
Does anyone have any input or solution for us? Again, we're no familiar with Siemens software, so we aren't sure if we even have the ability to transfer to this unit.
Old February 1st, 2021, 11:29 AM   #2
sigmadelta
Canada
sigmadelta is offline
Basically, you need Protool or (Protool/Lite) software and an RS-232 cable in order to download the .pdb file to the OP7.
Here is the cable diagram:
https://support.industry.siemens.com...egung_06_e.gif
__________________
Automation Programmer
PLC / HMI / SCADA / SQL
New Systems, Modifications
System Upgrades & Conversions
Siemens EPROM & EEPROM Service
Visit: contrologica.com
Email: info@contrologica.com
Old February 1st, 2021, 11:30 AM   #3
moggie
England
moggie is offline
moggie's Avatar
You will require Siemens Protool for the .PDB file.
(WinccFlex can be used once the project has been upgraded)
The IF 1A interface on the OP7 can be used for loading the program as well as interfacing to the PLC.
https://cache.industry.siemens.com/d...v1/Op717_e.pdf
Old February 1st, 2021, 11:31 AM   #4
JesperMP
Denmark
JesperMP is offline
JesperMP's Avatar
Yes the .pdb file is the Protool backup - great that you have that at least.
The Protool program can be migrated to something newer, either WinCC Flexible or TIA. It is probably best to go for TIA. Since the WinCC Flexible operator panels are also discontinued.
It will take some effort.
You have to migrate from Protool to WinCC Flexible 2008 SP2.
From WinCC Flexible 2008 SP2 you can migrate to TIA.
You must expect to check and modify the program since there is nothing in TIA that is 100% the same as the old line-based OP7 panel.
I think it would take me a days work to migrate the OP7 to a recent Siemens Basic panel.
__________________
Jesper
NOTICE:
JesperMP has passive-aggressive tendencies, can be impolite and may even use sarcasm !
Also: ᛁᚠ ᚢᚬᚢ ᚴᚬᚾ ᚱᛅᚬᛏ ᚦᛁᛋ ᚦᛅᚾ ᚢᚬᚢ ᚼᚬᚠᛅ ᚴᚬᛁᚾᛅᛏ ᛘᚢ ᚱᛅᛋᛒᛅᚴᛏ
Old February 1st, 2021, 11:36 AM   #5
JesperMP
Denmark
JesperMP is offline
JesperMP's Avatar
Oh, I missed the bit where you stated taht you already have a refurbished OP7.
Yes in that case you need someone with the Protool software to download the program onto the OP7.
__________________
Jesper
NOTICE:
Old February 1st, 2021, 12:16 PM   #6
RockyLeafs
Canada
I"m sure the customer wouldn't mind upgrading to a new HMI if needed, but like I said we dont play much with the Siemens stuff.
If this was AB, i'd be done already.
We have a very old laptop with ProTool on it (part of our company taking over), but so old the a USB flash doesn't work.
Old February 1st, 2021, 12:19 PM   #7
sigmadelta
Canada
How about a floppy disk drive?
__________________
Old February 1st, 2021, 02:41 PM   #8
RockyLeafs
Canada
Any Siemen ProTool contractor looking for a easy job?
Old February 2nd, 2021, 08:40 AM   #9
sigmadelta
Canada
Protool Contact
Quote:
I sent contact details of I guy I know via private message.
__________________
Old February 2nd, 2021, 11:46 AM   #10
JesperMP
Denmark
JesperMP is offline
JesperMP's Avatar
Just want to mention this, even if it may be too much effort.
You can convert an old PC to a VM. You would need to lift the image of the HD off the PC.
You can remove the harddisk of the old PC and connect it (PATA or SATA interface) to an external adapter of another PC. Then use that to create the image and convert to VM.
In the VM, you can then connect to the OP7 via a real serial port or a USB interface.
__________________
Jesper
NOTICE:
Old February 2nd, 2021, 11:49 AM   #11
JesperMP
Denmark
JesperMP is offline
JesperMP's Avatar
Actually, Protool does not use licenses (except for PC runtime, but that is irrelevant for this topic).
So if you can locate the original Protool software, you can install it on any new PC (up to Win 7 32 bit), or a newly setup VM (with XP or Win 7 32 bit).
__________________
Jesper
NOTICE:
Old February 2nd, 2021, 02:11 PM   #12
JOLTRON
United States
JOLTRON is offline
JOLTRON's Avatar
I thought it was only officially supported up to Windows XP SP2.
But there are reports of people getting it running on Windows 7 64 bit and Windows 10 (32/64 bit not stated)
https://support.industry.siemens.com...7/66736?page=0
https://support.industry.siemens.com...=0&pageSize=10
But I see it as possible since I have run Step7 Micro/Win on Windows 10 64 bit.
Old February 2nd, 2021, 06:45 PM   #13
JesperMP
Denmark
JesperMP is offline
JesperMP's Avatar
Quote:
Never let a 'not offcially supported' hold you back.
__________________
Jesper
NOTICE:
Old January 12th, 2023, 06:33 AM   #14
Aliabadi
Iran
Aliabadi is offline
I guess I can do this project for you.
Old February 5th, 2023, 01:32 PM   #15
Aliabadi
Iran
Aliabadi is offline
Quote:
Originally Posted by lizeenan View Post
Are you a Siemen ProTools contractor searching for a simple job?
Yes I am.
I can do WinCCflexible and Simatic manager projects too.
And many other automation projects by means of siemens products. In many industries such as : Automative , steel, cement and cement products and .... .
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
siemens hmi op7 op77 software winpandiyan LIVE PLC Questions And Answers 1 June 25th, 2016 11:54 AM
Siemens NTP sync PLC VS. HMI JOLTRON LIVE PLC Questions And Answers 2 February 1st, 2014 02:46 PM
Upload from Siemens HMI to retrieve source file?? Simon Webber LIVE PLC Questions And Answers 4 November 23rd, 2011 02:08 AM
Siemens S7 – 300 PLC and WinCC Flex 2007 HMI peng LIVE PLC Questions And Answers 3 March 17th, 2011 04:13 AM
S7-315 and Siemens MP 377 HMI Comms problems smakdown61 LIVE PLC Questions And Answers 4 December 3rd, 2010 09:13 AM
