Stuctured Text And Input Sensor
dschmiddr
Nov 2013
Sacramento
If an input sensor sees an object and the PLC will count it then how can I do this with Structured Text. Since there is no one shot with ST the program I cutrently have will increase the value for each scan while the input is true.
if bool and not bool_old then
count := count + 1;
end_if;
bool_old := bool;
But you should be able to call a one-shot-function in ST as well? Might depend on what system you're on..
The usual functions are called R_TRIG for Rising Edge Trigger, and F_TRIG for Falling Edge Trigger.
Since AB (and I suspect you are using AB) names anything and everything differently, the functions are called OSRI and OSFI.
Edit: Dirt's example can also be used for falling edge with a "NOT bool AND bool_old" check instead.
I'm using RSLogix 5000 v20. I have created a User Defined Type that I would like to zero out in Structured Text. In Ladder I can use the FLL...
3,118
I tried the click plus PLC to send emails today but could not get it to work over my network. I need a mass alert when a temperature reaches a...
142
can the slc500 5/05 send a email and text over Ethernet ?
153
Good morning. I'm doing a rehab and I need to recycle some part of the old code that won't change and that I need. This is a calculation that...
22
1,170
I'm writing some structured text that's handling a data structure that comes from a PC. The PC structure is in the "new" LREAL 64-bit floating...
440
