AutomationTechBrian
I'm fairly new to working with servo control. My training is coming, but I have a customer that needs help right now, so I'm trying to read/work my way through it to help him out.
He saw that the "arm" was not in the right position, so he forcibly moved it while it was powered up. Afterwards, the Kinetics 6000 drive showed a fault 16. I'm trying to figure out how to eliminate the fault or move the arm to a position in the range, then reset the home position.
I tried to understand the process for resetting fault 16 before I got on-site. The posts said to change the fault action to "status only" for soft overtravel to eliminate the fault, and then jog it back into position to clear the fault. Then I could work on getting the "home" reset.
As you see in the pictures, it is more complicated. Changing the fault action did not work. I think there are issues I can't clear. Not sure how to proceed. Any thoughts? (see attached picture)
