Guitarmaestro69
We have several PV Plus 7 HMIs that will not allow us to connect to it's file server for file management. I've confirmed that the settings are fine. Firewall is not an issue. Other HMIs have the same settings and are on the same VLAN and work fine. When I attempt to connect, I get a connection failure along with a prompt for credentials. This setting is turned OFF in the HMI. No idea why I'm getting this.
A fellow engineer called rockwell and they failed to help. They suggested resetting to factory default, which worked for him, but I cannot do that. Perhaps I'm missing a setting somewhere?
FT ME version 9 is used.
