Mark Snodgrass
We are going to be upgrading some equipment in our planer mill. It currently is being controlled by a PLC5/80E, and the new equipment will be using a new Control Logix processor.
The install is scheduled for only 9 days, so we are trying to make the control switch over as smooth as possible prior the shutdown.
The new processor will be in a different location and there are a lot of devices that will not be changed with this upgrade. We are looking at installing Flex I/O in the remote locations now, so that we only have to run the Comms cable and the control power to the new processor.
The question I have is if it possible at all to control Flex I/O from a PLC5 using 1794-AENT adapter module. We want to use Flex I/O since we already use it in other applications, and since the Compact Logix will control all of its remote I/O with Ethernet we want to use that if possible to avoid buying another adapter module for only a short time.
Sorry for the long post, but I wanted to put as much info as possible so you understand what I am trying to do.
