Hello,
I have a Festo SEC-AC-305-PB drive and it came with S7 function blocks. The Festo comes with its own commissioning software called Wmemoc where you can set the drive up and monitor different parameters. The Siemens S7 parameters for position setpoint, velocity, etc are configured as DINT (double integer). I want to know how to scale that or convert the number in my PLC to match the values shown in the Wmemoc software. I do not know what number format the drive uses but if I force a decimal value for position that is L#40000 and send that to the drive, the drive shows a number of 25,396820. I want to be able to enter a scaled value in the PLC so that the position shown in the drive Wmemoc software matches the PLC.
Has anyone used this drive with the S7 funtion block that comes with the drive?
Also where can I find a good conversion utility for integer to double integer, decimal to integer, etc?
Paul
Paul
