It appears that the slip rings are 3-phase, 1 phase bare, 1 marked yellow, 1 marked blue. If so, this could be a wound-rotor motor, with a rotor having a coil fed by slip rings (instead of the usual induced-current rotor). The speed of a wound-rotor motor can be changed by changing the resistance between A-B, B-C and C-A of the wound rotor leads. Before electronic VFDs, wound rotor motors were used in cranes and other large loads.
Definitely a Wound Rotor Induction Motor, too many stator connections to be DC, too many rotor connections to be synchronous. So your control cabinet would have likely had a set of contactors for the slip ring portion, the one on the left, which is what you may have interpreted as being Wye Delta, but it is not. The contactors go to external resistors that are turned on with the stator, then in stages relating to the desired torque /speed, you short them out. The lower the resistance, the higher the torque/speed, so the final stage is for the resistors to all be shorted out. That last contactor then looks like the shorting contactor of a wye delta starter.
If, as is obvious, you have never seen a WRIM before, you will have a learning curve ahead of you to get it running, and that may be especially difficult if the resistors didn't come with the machine, as often the case because people don't understand them. The motor can be run via a VFD if you use a good quality Vector drive, and take the motor to a rewind shop and have them short out the slip ring connections on the rotor. Do not try it yourself, it has to be balanced again afterward and do not just short them externally, because as the slip rings and brushes wear out, it affects the ability to use the VFD. Also don't use a cheap VFD even if it says it is vector capable, many of the el-cheapo brands just lie about that, to avoid burning up the motor by starting it with the rotor shorted, the VFD must maintain very accurate control of the current.
This might help get you started.Luckily, the old control cabinet is there, so I can go take out the resistors and use them. The new controls they bought just have an across the line starter. It looks like I'll have to rewire the controls for that motor.
Thanks for the help. This was a new one for me.
I've got it figured out, now. I have talked to the facilities manager and he is thinking over what he wants to do. He may replace it with a standard 40hp motor. If not, we will have to add a cabinet to install the resistors and contactors in.
I appreciate all the responses. I've learned some stuff today.
Just a word of warning; WRIM torque capability is higher for starting / accelerating than a standard off-the-shelf induction motor. Know your machine's torque/speed requirements in detail before choosing to replace that motor, it might take a larger HP rating to get the same performance.I've got it figured out, now. I have talked to the facilities manager and he is thinking over what he wants to do. He may replace it with a standard 40hp motor. If not, we will have to add a cabinet to install the resistors and contactors in.
