power shielded big cables brands
Kataeb
Jan 2007
www.livelovelebanon.com
636
Kindly, do you know another brand which makes "power shielded big cables" similar to the below ones?
Power cable sold by the meter type: 6FX5008-1BB35 4x 35 C UL/CSA, DESINA MOTION-CONNECT 500 Type of delivery: up to 14 m ring from 15 m drum Dmax=31.5 mm, Length (m)= 30 Siemens
Power cable sold by the meter type: 6FX5008-1BB70 4x 70 C UL/CSA, DESINA MOTION-CONNECT 500 Dmax=42.6 mm, Length (m)= 30 Siemens
Power cable sold by the meter type: 6FX5008-1BB12 4x 120 C UL/CSA, DESINA MOTION-CONNECT 500 Dmax=56.0 mm, Length (m)= 30 Siemens 6FX5008-1BB12-1DA0
Must they be labelled desina ?
If any flexible 4x35mm2 with screen can be used, then there are a million suppliers.
Rather than using the Siemens cables as example, state the specs that the cables must fulfill.
Kindly, do you know where can we find bigger size Shielded Power Cables (for drives) , similar to the below ? 150 mm2 ? 185 mm2 ? Thank you...
956
First time I've used either the software or this unit. This is the setup I have right now. I have 20mA coming into AnalogIP1. Both the Main.PV...
38
Hello..I am new to Plc.I have Mitsubishi Melsec Fx3Ga-40MR PLC controlling a machine for packing powder.Currently the Plc has issue which power...
135
Hello gentlemen, Im working on a small project on TIA Portal, about establishing a Modbus TCP connection between my ET200SP plc and a socomec...
302
I have the power supply in the link below. If we want a breaker to isolate and protect the input side how would I size that correctly being 120...
203
