Small TouchPanel HMI that can print simple text reports?
dguedez
Feb 2011
Austin
19
si'm looking for a small,inexpensive, touchpanel HMI that can connect to a printer to print simple text reports. The HMI will read data from a compactlogix/micrologix PLC. Right now, I'm looking at a intouchME panel but i feel it is overkill and does not do exactly what i want it to do. It can print windows or take screenshot with scripting, but I really just need it to print a simple text template report.
Suggestions/recommendations welcomed.
Do you have a printer make/model specified or in mind?
not really. An inexpensive inkjet/laserjet printer will do. I'm guessing the HMI may dictate what printer i will need since they don't always support just any printer protocol (PCL, etc).
What do you consider inexpensive?
Not siemens. I say Redlion,Cmore, Eztouch, are fairly inexpensive. Maybe not go above 1500.
EDIT: maybe not over 2000, i have my eye on the windows 7 embedded eztouch HMI which is around 1700, but i have little experience with them. The customer does have a small eztouch panel in the field though.
Why add an HMI to achieve a simple print function?
You can print to a Zebra direct from plc. No need to add an HMI just to print.
Thank you for this, ill look into it, I think we also would like the HMI so they can edit data on the PLC, such as make corrections. Something they don't have right now. But i will look into this "Zebra".
...and I agree. Context: TIA Portal/HMI = KTP1200 (12" screen) In the attached redacted image, the values in the white boxes are entered by the...
683
Hi all, I’m new to programming and want to write a simple routine. Push start button, turns on sensor. 2 second delay before anymore logic read...
326
Hi! I'm wondering if PLCs are used for small-scale production. I've got four machines doing different things with textiles, and I'm exploring the...
1,328
I am looking at an application where I will need to detect small hairline cracks in stamped metal parts. The sensing will need to be done in the...
1,122
Anyone know what the little green triangle on SCREEN 3 means ? See picture Thanks
450
