RSLogix Calculating 1st Monday of the Month
ksmohammed
Jan 2018
Dallas
Hey guys,
I need help calculating first Monday of the month. Has anyone ever had to perform such calculation? Rockwell has UFDB that calculates the Day of the Week.
Hey guys,
I suspect that I am mis-understanding the question, but here goes:
When you use the GSV to read the date and time into an array of dints, I call mine PLC_DateTime, index 0 is year, 1 is month, 2 is day
EQU PLC_DateTime[2] 1 ons First_Day_Oneshot ote Your_New_Tag
I would think you should be able to do that with a bit of code once you have the following:
- Day of the week
- Day of the month
- New month tracking bit
Once you enter a new month, you set the New Month tracking bit then look for Monday...
I don't think you'd even need the tracking bit, given that the first Monday (or any other day of the week) would occur no later than the 7th day of the month.
I *KNEW* that I had not understood the question ... why can't you see that sort of thing BEFORE you hit SUBMIT?
I would think of in only two conditions:
Day of week is monday ( this routine already exists) and day of the month (very easy to get) less than or equal to 6.
if those conditions are true the that is the first monday of the month.
Less than or equal to 7... Today is a good example. :)
All - I am writing a control panel program in RSLogix500 f/u/w a MicroLogix 1100 PLC controller. I have 8 exhaust port temps stored in...
14,789
111
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
130
210
206
