PLC Pie Guy
Hey folks.
Quick question about direction control on a PF70.
The control is all over the connection on the 20-COMM-E. Start, Stop, Speed Reference and such.
I'm asked to reverse the direction.
I see that the parameter 190 (Direction Control) is set to 0.
0 = Unipolar control with drive logic.
In the code I see a start bit mapped to bit .1 of the Logic Command Word to make it start. I see them stopping the drive with .0 of the Logic Command Word. All makes sense.
I don't see them writing to bits .4 and .5 of the Logic Command Word making the result = No Command for direction according to the manual.
The odd thing is, in the Logic Status Word, I have coming back a true .2 and .3 bit indicating that I am commanding in the forward direction and running in the forward direction.
My question is, If I'm giving no direction command to bits .4 and .5 of the Logic Command Word, should I still be seeing a forward command in the Status Word true in bit .3 as a default, or am I missing something somewhere, whats making bit.3 true?
I didn't look at the drive wiring as its inaccessible at the moment but the drawings show nothing wired to the terminal section or anything drive control. I was suspicious that here was a fwd input there hardwired that would give back the status bit .3 as true for forward.
I'm used to 525 and PFlex 40. Perhaps I don't have to, but I always will make true the fwd command bit in my programs. This isn't my program in question though.
Thanks for and tips!
