FileWriteFields Question for WonderWare InTouch
So you know have RunData 1 to RunData 3, for Date, Time and Data from tag.?
How often do you want to save the file?
Save on time change?
Save on data change?
Yes on data change i want save new file. But in some cases the billet weight can be identical then it should not overwrite the old one
the is my script right now and the file is saving on this name, 19072020.CSV
FileName = Text ($Day, "00") +Text ($Month, "00") + Text ($Year, "00") + ".CSV";
FileWriteMessage( "D:\logfile" + FileName+".csv", -1, $DateString + ", " + $TimeString + ", " + Text( CPU21_BZ90_DSP_R112, "#.00" ),1 );
i just want to add after date 1 , 2 , 3 ,4.....incremental serial number for every new file
How can i get the value, suppose I have a slider and # (analog value display). I want to use the filewritefields and filewritemessage to see the...
1,504
I recently uploaded an aplication from a Panel View, created a new screen and now that I've downloaded it to the Panel View, all the texts have...
155
I have never had the pleasure of working with a "Thermistor" until now and have a question. The Thermistor is a 10KOhm 4-20mA 2-wire device and I...
136
Hi All, So I have a main routine with an instruction that's executed by XIC "Run" I have a JSR located on a rung below it. In the logic for that...
242
I have a 120V relay, 120V DI card and a analog input. I was wanting to know if i could put a 24V DI and well as a 120V DI card on the same plc...
104
