Hello,
I'm using Factory Talk View SE. I have a Trend display with few Push button to invoke different trend templates.
Let's say this display is saved with template#1.
If i want to edit Template#2, i right click on template#1 and hit properties. on the template tab, I Load Template#2. I edit template#2 (differents tags, differents scale, different data log etc... than template#1), i hit apply in every tab i changed. then i go back to the template tab, I hit save template and write the template name. It's asking me if i want to override (as template already exist) I say yes to save.
I close the display (without or with saving the display has the same result). i open the display again, load the template#2, and here, my changes are not there, it did not save.
Any idea why?
Thank you for your time
Any idea why?
