Just display the four values separated by a period in the HMI.
In the HMI create a text object that uses an embedded variable for the left most value, then put a period. Then add the next value with another embedded variable. Then another period. Then the next value followed by a period. Then the right-most value.
That's how I would display it on the HMI. Note in my example below I added a return after each line so this would be easier to read. But they would all need to be on the same line to display correctly.
