fabula
I have a nice project in Visilogic that I have been asked to re-create in Tiaportal/Siemens. (Bosses / maintenance want to standardise on one manufacturer)
I can export each sub-routine to a .vlx. Opening this shows a header of a "Standard Jet DB ", but if you open it with e.g. Access, it doesn't seem to be standard.
Is there any way of converting/exporting the project to another format/structure?
Are there any businesses that offer this type of service?
( I get it that there may be no instant conversion tool, but some half-way process of dumping each block, converting it, having to re-write all the inputs but not the ladder etc., would be better than having to re-write it all from scratch. Especially if you would have to learn a new way of interpreting the programming from the one you are used to.)
