Hello PLC Experts,
I want to do a logic where in an analog value will be captured per second or in any time possible and move that value into a placeholder tag when an enabled bit is energized. Its like getting sample value.
Example: You have a variable flowrate/Level. Then you have an enable bit that when it is energized it will get the flowrate/level at that moment and then move it into a place holder tag.
What instruction should i use? how do i do this? thanks!
