Programming of PLC 5/40 E backup system
hrauf
Dec 2011
Sadiqabad
I have a PLC 5/40E redundant system (using two 1785-BCM Series B modules) with two remote IO racks and an operator / programming HMI connected via DH+. I want to modify the ladder logic of both processors (an apparently simple task for many of gurus here) for which I need both logic files offline. I have uploaded the currently running logic file (from primary processor I presume as this is the processor which appears on DH+) using RSLogix5 over DH+.
For BCM systems, I am aware that secondary processor can be accessed using n+1 address (n being the primary processor address which in my case is 0 as per the logic file retrieved by me). With this philosophy, address of secondary processor becomes 1. Now I am not clear on how to access this processor (from RS Logic / RS Linx) so as to upload existing and subsequently download modified file in this secondary processor. As per my understanding, the network shown in RSLinx will only show me the primary processor. How can I access secondary processor using the node address?
Hello colleagues, Some time ago I started my adventure with programming. With your help and the courses, things are starting to come together...
681
Dear All, I need a sample PLC program to count the output pulse of a mass flow meter so that a specific amount of mass (for example 100gm)can be...
146
Hi Please I have zeilo smart relay #SR2A201BD but I don't have it's programming cable. Can I use any general usb/rs232 converter? Or need...
158
Hi, Does anyone have thoughts or know of, can point in the right direction any published materials with a plumbing centric point of you explaining...
164
@ All: what is your best guess on a potential range in increase in efficiency in % (i.e. saved programming hours, greater output, etc.) when...
349
