Help with Tool Changer Program
cartierusm
Oct 2016
San Francisco
25
I'm trying to control a tool changer on my retrofit CNC lathe that I built. I have experience with PLCs, but not much. I'm using a click PLC.
The tool changer has 5 proximity switches, NPN, and a combination of 3 of those switches ON is a position.
Look at the pics. When I write a program for a single position, such as the first pic, it works of course, but I can't figure out how to program it so I can press a different button to have it stop on different positions.
The second pic show basically what I want to happen. Any help would be appreciated.
You're close...your first pic is what you want but instead of set/rst the output set/rst a memory bit that represents go to position 1. Then make two more exactly like the first two rungs but set/rst a memory 2 bit and a memory 3 bit. Then use those three memory bits in parallel to turn on your output with an OTE not a set.
I would:
  • have each X00n transitional drive its own separate Y00n latch
  • include in the latch (set) rungs the OFF state of the remaining Y00n outputs ( Y001 can only be set if 2,3 and 4 are OFF, and so on)
  • parallel all the Y00n outputs to drive one Y motor enable
  • use the Y00n to enable the logic for the prox switches
YMMV
I don't know Click well enough to know the internal memory tags, but this should be what you need.
EDIT: Doug posted as I did, but same thing...his rungs have interlocks in the PB rung in case any other mode is active, which I don't know from limited information if you need. Also don't know if you have any STOP PB's, but those would be put in parallel with all the RST rungs.
Awesome, thanks gentleman! I'll give that a whirl and see if it works. I'll also study it to understand what it all means so I know for next time. I've done latches before with help from others on here, but don't quite grasps how they work yet. I think I need a real work example, a physical example of how they work.
Thanks Chaps, works a treat.
Now if i can figure out how to get it to stop at the correct position. It's over running by a little bit.
Is there a way to have the click plc react faster? I know you can change scan speed, would that help?
I doubt PLC scantime is your problem. More likely it's physical/mechanical. Relays have to switch, solenoids have to physically travel, everything has momentum and inertia...I mean, without checking out your system I can't say for certain that PLC scantime is your problem, but I highly doubt it.
True, but this is the original setup and the old electronics did the job, and they were from 1978.
After I wrote this I realized that it probably was mechanical. I then figured that the original motor, which I'm using, probably was hooked up to a VFD of sorts and that would stop it instantly. I think what's happening is it's coasting a little after it shuts off. I've got a VFD so I'll try that.
BOOYA!! It's working. Thanks for the help. I hooked up the VFD and exactly what I thought. It's working perfect now. Now I just have to interface it with my CNC program. Which I have no clue of. Off to another forum.
I APPRECIATE ALL HELP!👼 I am trying to set up a tool changer on a lathe. Disclaimer :): I have never used a PLC or the software to...
34
16,904
Hello Team, I am desperate for some help with an assessment I have as part of a Level 3 general engineering course. I am in a role that is much...
345
Hi, I have a new PanelView Plus 1000 that I am using to replace an old Panelview Plus (pre v6, I'm not sure exactly what version). I have a clone...
2,783
i finished a new project by protool v.6 sp3 on win xp , i have S5 TTY Programming Cable when i connect to op 15 display transfer ready but when...
1,278
This is a different problem but on the same machine as my other post. Basically there is an alarm message showing up on the TP270 HMI, and I am...
6,622
