Help with visualisation - text field input
shrimper
Jun 2015
Warsaw
I would like to put a text field in my visualisation, where user can put some data (string or int). Then, after clicking a button, this data would be saved into MAIN(PRG) variable.
It seems that "Text field" is capable of only displaying text and variables. After I login and run program, placeholder %s disappears and variable from "Text variable" is displayed - but user cannot modify it.
I would like to give the user opportunity to edit content of this Text field by clicking on it and typing data from the keyboard.
I use TwinCAT 3 in Visual Studio 2013 Shell. There appears to be no alternative to "Text field" - maybe I miss some libraries? How do I add them?
Please answer :)
Regards,
shrimper
You just have to set your input configuration. Just go to your element property and set your input configuration for example to "one mouse click", then choose "Write a variable" and so on...
Thank you, it worked like a charm. I thought "write variable" just saves some predefined value into a variable, and was so sure about it that I never checked it out :)
Another curious thing is that after I click any button, the text I wrote a moment ago just disappears, although nothing in my code is capable of reseting it...
assoon as you entered the text, you will need to save it, as the program will keep running, it will overwrite what you typed.
133
Hi all I need help on this As in my project used Schneider TM241 controller. Now I want to communicate Elite energy meter with controller by...
116
133
Good day all! Can someone help me with the procedure to update Beijers E700 firmware? The Panel I am working on is firmware 2.04v and I would...
54
Hi, We have an application that has a device that goes through a reboot (appears un-graceful) What then happens is the MVI module appears to hang...
59
