Siemens Step 7 Monitoring SF Indicator
Open the project > Right click the CPU > Go to PLC > Operating Mode
Or you can go to Module Information > Diagnostic buffer.
Just keep in mind that if your error causes your cpu to stop, SFC51 will not be accurate since it is not being processed.
Hi All, I have written an indexed program that controls 8 identical machines. Each machine has an identical DB which contains a map of all its...
2,352
Good Morning, Hoping someone with some Siemens experience can give me a hand with this one. Customer has a S7-200 cpu, which has a 6GK7...
244
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
545
Hi Siemens Experts, I am hoping someone can shed some light on my issue. I have uploaded the code from a S7-300 (317-2PN/DP) using Step 7...
664
Hello, We monitor the temperature of a pipe via a 4-20mA temperature transducer. This goes into DB135(Read Analog Inputs). The issue I have is the...
624
