Citect log files
rahilansari
Jul 2008
INDIA
103
Can anyone tell me where I can find dump of all log files generated by Citect V 5.21.00 Service Pack G. I need the file names or please advice if I need to generate them through cicode commands.
Do you mean the crash logs ?
Citect is pretty well documented so i would think the help file would be your best staring point, i have only ever used Citect from V6.x so cant tell you exactly where they are in that version.
Yes, I want crash logs and all other events that Citect logs.
It only logs what you tell it to log and even then it will place them in various locations depending on what is setup
It won't create crash logs unless you tell it too either
So in both cases you need to look at the system and see what its dong, unfortunately there is no generic answer to your questions.
Hello all! I am new in Citect SCADA. I need to create material tracking system in which I have a dozen of photometric sensors. When each sensor...
3,001
Hello, I have configure some digital alarm and thats alarm i have to Log in SQL using cicode but when i am trying to this this it cant work...
2,543
Hi Guys, Hope someone can help with this. I am trying to log variable changes to a text file using the Log device in citect Scada 7.4x My Log...
3,903
Hello everybody, I'm using Vijeo Citect v7.40 and I would like to keep a log file with all user login related information: time/date of every...
2,454
