master slave configuration
rameshgurav31
Nov 2007
mumnai
Dear Sir,
If my master PLC (say PLC1) is receiving data from slave devices, them can I use other PLC to work as a master (say PLC2) and take all data from PLC1.
If yes, what is features required for both PLC.
Pls confirm whether we can use the two different com port of the same PLC to configure them as master and slave, so that PLC can take data from slave devices from master port and send data to other master PLC from slave port.
Comm port say RS485 and protocol is modbus
Regards,
Ramesh Gurav
As long as the port can be configured as a slave, then you should be able to do it.
The real question is why you would want to. You already have the existing master reading data from the slave. It seems to me it would be less work to add logic to the existing master's communications routine to have it write its data to the slave.
Hello Guys, Please I need assistance on how to configure Powerflex 755 VSD as MASTER & SLAVE setup in Rslogix 5000 using TCP/IP network. Please...
2,613
Is it possible to configure an Allen Bradley panelview 1000 series to be a modbus RS485 slave? I guess I am not certain exactly how/if that would...
3,638
Gents, I just want to ask if it is possible to configure CIF30-DPM/CIF104-DPM into a CIF30-DPS/CIF104-DPS using the jumpers/connectors and...
1,533
Hi all, I am new to the whole As-i and S7 world. I added a 3RK1400-1DQ00-0AA3 41/40 Slave and configured it as slave 2 with hand held...
1,531
Hello again! I have a little question for you guys. I want to link two S7-300 controllers via Profibus (Master - CPU 313C via CP 342-5, Slave -...
2,624
