ControlNet Keeper and Scheduling
The RA PCDC Search for "EDS files for 1756-CN2" returns all series (A, B and C) from A 10.008 to C 25.005 including B 20.009, 20.011, 20.013, 20.020. You have to match the exact revision of the module.
Is RSNCN running on the same PC as RSL5K? If they are not the EDSs need to be registered on both machines.
The Rockwell Compatibility Tool does not show Series B CN2s compatible with L55s at Rev.15; only series A. It doesn't get Red-Xed, however, doesn't get the green check either.
I downloaded the EDS from Rockwell and it was supposed to have A, B, and C, but it actually only included A and B. But I was able to get the right one by uploading from the device.
Everything is on the same PC.
This is the crazy thing about the compatibility..... It has been working for quite a while. And it was working with the PLC program set to a 1756-CNB, but the actual card was a 1756-CN2. It was when I changed the RPI in RSLogix when everything came to a screeching halt.
Did I read correctly that only one node shows up in RSNetworx?
The only node to show up was the card itself. No devices would show up in a network scan.
On a Redundancy system, If I Optimize and rewrite the Keeper (SAVE) file to the primary chasis CONTROL net module, shouldn't the Redundant racks...
3,614
Hello Can anybody tell me about Keeper in RsNetworks 1756-CNB/D; and how to use it as active keeper. I don not have *.CX file (config file) How...
2,263
Hi, it's my first time that i post a message but i found a lot of answer here before! I have a problem scheduling my CNET network. This...
7,556
Hey everyone, looking for advice in this particular scenario. Currently we have a controlnet bus that has (6) CN2DN devices and (2) powerflex...
207
Does anyone know of a cheap USB to ControlNet or USB to DeviceNet adapter (I'm looking for both). I thought PLC Cable would have one but I did not...
2,279
