RSlogix 5000 timers for start/stopping a agitator sequence
remullis
Oct 2012
Georgia
179
Hello all,
I have not used many timers in logix and was wondering what is the best method to do the following?
I would like to start an agitator 25secs on and 10secs off for a 5 min cycle.
then after the 5 min cycle the agitator should stay on.
I know there a lot of ways to accomplish this but I'm not sure what may be the simple way of do it.
Rich
One On/Off cycle is 35 seconds. The system would be in the middle of its 9th cycle when 5 minutes is up. Could you change the timing to yield 30 seconds per cycle or possibly change to constantly on at 5 minutes 50 seconds?
Or do you just want to switch to constantly on wherever it is in the On/Off cycles?
correction, after the start stop sequence with 5 minute 50 seconds duration I would need the agitator to stay on an additional 5 minutes no cycling.
Rich
thanks guys. I was able to get this working properly. I read using the LIM functions as well. I may take a look at that later.
rm
I haven't used used timers and STL together, so thought I'd try them on my next project! I have the following code example: So basically I was...
3,117
I have a merge program that a co-worker was working on before he quite recently. In the past month the merge logic grew from 17 rungs to now 49. I...
2,742
Hello, I am trying to have 1 timer turn on a horn 4 times for a total of 120 sec. Is it possible to split a TON up into 4 times or do I split...
2,843
Hi Guys, Is there a way to reuse TON timers in RsLogix 5000? I used TON, then after it's .DN, then I RES it. Later on, I reuse the same timer...
7,109
Hi mates! I've got a very easy question here for you.... I need two clock pulse signals as the following scheme shows: |----|----|----|...
5,628
