Block an analog signal
Lary
May 2020
MI
58
I am running RSLogix 5000 20.05 with a AB Compact Logix 5370 PLC. I need to block an analog signal after 7 seconds for the remainder of the cycle. I'm wondering if there is a way to do it? Thank you.
Just don't read it after seven seconds.
Enable a 7-second timer while you are "on-cycle", and use the timer's .TT (Timer Timing) bit to enable reading the Analog Input.
Once the timer has timed out, the .DN bit comes ON, the TT bit goes OFF.
Reset the timer when the cycle re-starts...
Hi, I want to write a logic, I have total 6 analog input of temperature and have 1 drive. Now i want to start drive when any one of 6...
1,602
Hi Friends, Please, who can tell me the Function Block used for scaling 4-20mA to say 0-200PSI in Mitsubishi GX Works3?
7,295
Is there a armorblock type of that includes digital and analog I/O? All I can find is Digital.
1,431
I've got a SLC with a RIO scanner 1747-SN and a flex IO DIN rail 1794-ASB with an analog output module 1794-OF4I Now I've found example code etc...
2,318
Hello All!! I am new to the forum and have seen alot of good answers so far, but I have not been able to resolve the issue I am having. :mddr...
4,269
