Hello All,
I need some more clever help with a problem. I am using Revision 30 RSLogix but having a problem. I need to be able to send a value to an object that requires the number 0-10000 split up in a high byte and low byte in hex. So for the number 5000 (decimal)= 1388 (hex) I need to get 13 into the high and 88 into the low. I will include a picture below.
Thank you for the help!
