jechlu
I'm a licenced electrician and I took courses in Network administration.
I have problems getting two modbus devices talking to each other over a 2 wire 485 modbus RTU.
one is a twido plc that has an ethernet port, a din port and a RS485 3terminal adapter.
the other is a Delta Controls DSM BacNet Gateway, with a 485 port flashed with modbus protocol.
What Ive learned so far.
the Gateway has to be grounded for the controller to communicate with my plc.
My port is setup as a slave 19200br, 8N1 RTU which is the same shown on his controller.
He is getting invalid response from his port statistics. I've talked to both his tech support and Schneider's and all say that their end is well configured....as usual.
at this point I'm leaning towards intalling a 485 to ethernet converter and hopefully this will rectify my comm problems.
My question is do these converters usually retify these types of problems or am I simply wasting my money?
How about a OPC Server? its a bit overkill for a small system. But I'm not too familiar with opc in an automation setting.
