Send a string from Allen Bradley to ABB robot
backendcode
Aug 2017
brampton
249
Hello Everyone,
I want to send a string from AB PLC to ABB robot control. I can send integers from PLC to abb robot using group input but not sure how can I send a string with a handshake.
Any advice or suggestion will be appreciated.
Thank you again,
Use an array of group inputs if you have enough free. Are you using ethernet/ip? Fanuc allows explicit messages in addition to cyclic, but I can't recall if abb supports it.
Thank you jstolaruk,
I was thinking about it but then if I need to send 10 character string which is 10 bytes so I might be ended up using 80 bits point on I/O card in ABB controller which is a lot.
Yes, I am using ethernet/IP.
I might try to post the same question at robot forum which you told me last time.
I was expecting some PLC programmer might use to send strings with a handshake between PLC and ABB Robot controller.
Thank again for the help.
Correct me if I'm wrong, but you shouldn't have to use physical I/O when using Ethernet/IP?
Do you also have Robot Studio, or are you using the FlexPendant?
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
427
Hello, I have a scanner connected to my Allen Bradley PLC and i can receive the scanned barcode in my plc as a String. Now i need to transfer...
1,943
I am trying to send data from my Guardlogix 1756-L72S to a Leibinger JET3 UP PI Printer trough a MSG instruction, I can send information if the...
4,199
Hi All, I am currently developing an application using a L18ER PLC and a JET 3 printer. The printer prints a 2D UV bar code onto bottles passing...
3,464
Hi folks, I am using Vijeo Designer V6.0 to send ASCII string commands to printer. The printer is an inkjet printer that prints on boxes. I have...
4,186
