Rob S. Member R Join Date Sep 2008 Location Maryland Posts 739 Sep 17, 2019 #1 Good Afternoon , I have 3 old Panelview Terminals that I need to replaced. Could you tell me the replacement for the Panelview Terminal 600 2711-T6C20L1 with what model Panelview Plus 7 ? Thanks so much ,
gclshortt Member Join Date Dec 2014 Location Ontario Posts 3,217 Sep 17, 2019 #2 https://literature.rockwellautomation.com/idc/groups/literature/documents/ap/2711p-ap006_-en-p.pdf 2711P-T7C22D9P The above literature specifies this replacement. I hope this helps you out. Regards,
Big Brunsy Lifetime Supporting Member B Join Date Apr 2014 Location Iowa Posts 23 Sep 17, 2019 #3 You can also get a 10 or 15% discount off of the new one when you trade in your old one. They call it step forward.
Jeev Member Join Date May 2008 Location Brisbane Posts 737 Sep 17, 2019 #4 gclshortt said: https://literature.rockwellautomation.com/idc/groups/literature/documents/ap/2711p-ap006_-en-p.pdf 2711P-T7C22D9P The above literature specifies this replacement. I hope this helps you out. Regards, Click to expand... Adding to that, if you will not reach the screen number limit, you will save money by using the Standard version over the Performance version. 2711P-T7C22D8S
Ken Moore Lifetime Supporting Member Join Date May 2004 Location North, West, South Carolina Posts 3,474 Sep 17, 2019 #5 The Standard unit has a limit on alarming also. Learned the hard way.
