Compare TISoft Siemens Simatic TI505 ladder logic
firebirds11
Jan 2023
America
Hi.
I have 2 files where I would like to see the ladder logic differences (similar to the Rockwell compare function). I am using TISoft Siemens Simatic(R) 505 Family. Release 7.1.
I understand AUX 17 Compare from the program will compare the data and give you some information, but it won't tell you where in the program the differences are.
Is there anything else I can use (besides the compare) that will give me information about the logic differences?
Thanks!!
I think this is not possible with Tisoft (used it last time in 2005 so a long time ago).
We use the windows version from Tisoft called workshop and also in that software there is no option to compare two files.
The best option would be that you go online with the PLC and save the program (is also an aux function in Tisoft) then you have at least the actual code and data values from V K TCP etc memory.
When the program was modified between your versions and what,s in the PLC then you would only mis the symbols if additional adresses have been used.
Kind regards
Henny
Help please. Im new to Omron and have a machine down. I have a compare = for barcode label scan. I've attached two pics. On the Mnemonics you can...
616
Hi everyone! Accidentally closed it and it wont appear again. Checked and unchecked the option and seem to make no difference. Running v7.10.00...
1,879
I'm working on an array that contains a UDT of 5 Items Array[4] DataType[0] - Part 1 - Part 2 - Part 3 - Part 4...
833
Hello experts, I am just starting with AB programing, I have a questions regarding a compare done in an old RSlogix500 and causing me issues when...
1,924
I want to compare two GE 90-30 projects. But it looks like my ME program does not have a compare tool. I found GECompareEngine.ocx file in my...
827
