Modbus communications from Micro870 to Guardmaster 440C-CR30
bigsteve
Aug 2020
Memphis area
30
I am working on a project where an AB Guardmaster 440C is the logic solver for some SIL-rated interlocks. I need to be able to send reset bits over Modbus from a Micro870 PLC. I've got the 1761-BL-HM02 cable connecting the 8-pin serial ports. I've got the code going on the Micro870 ladder logic, and it's not giving an error, but I am not getting any data transfer.
My serial port settings on the 870:
https://drive.google.com/file/d/1uu3Exebc7hjMABDKiyaMAK9xBT01qM-H/view?usp=share_link
Modbus command configuration values:
https://drive.google.com/file/d/1Z6zX7GwdmVtQ-jxuEiLF5vwRzDLG_YL_/view?usp=share_link
Ladder logic line:
https://drive.google.com/file/d/1JuymC8tUWFPXlo11GBZPMYrC4U763LT6/view?usp=share_link
view
I'm having the same problem writing to the 440C.
I'm hoping it's something simple that I'm overlooking; I've got the ladder logic set up just like the example in the 440C manual, but there's not much information on the mechanics of it all.
Thank you!
Just working on a job with a heap of Schneider power monitors connected to my PLC with Modbus RTU. There are the usual D0 and D1 connections...
2,251
Hi All, I have a question would like to ask the experts: my system has two Rx7i PLCs and I'm having them communicate with an RTU (D25) via modbus...
2,093
Hi All, Just wondering if anyone can offer some help or point me in the right direction in regards to Modbus communications between a Micro820...
5,348
I'm re-writing a control scheme for some air compressors. Two of them have micrologix PLCs and the third is an Atlas Copco with MODBUS...
20
8,575
I have 6 lift stations through out a plant. Will be looking at 4-20 feedback from levels and controlling pumps. My plan is to use universal remote...
8,707
