Communication Micro850 to OMRON CJ2M via Ethernet/IP
Nov 2012
Pretoria
Good day All :)
I am using a Micro850 Allen Bradley PLC which must communicate and share data via Ethernet to a OMRON CJ2MCPU32 PLC.
I DOWNLOADED a Manual (attached to this post) which explains how to establish connection and share data between OMRON CJ2
and another AB PLC. Unfortunately this doesn't WORK FOR the Micro850 PLC. I got stuck where I have to edit the Micro850 PLC inserted
on THE NETWORK in the network configurator from Cx-One with the OMRON PLC communication adapter. I installed the EDS file for Micro850 but I am not able to edit in order
to create tags. It gives me this ERROR: " setup possible parameters not exist".
Can anyone HELP ME on how to sort this out?
Your help will really be appreciated.
Sonia
Hi, I have a AB Micro850 that needs to write and read on a CANOpen network with a Danfoss Display and Schneider Motor Drive 110kW, I'm using...
372
Hello. I want to use micro850 to read and write registers from 120 modbus tcp devices. I want to know if anyone that implemented such a solution...
474
I have a PLC that I need to have communicate with an Emerson VIM 2 module. I just need to write 1 array of integers from the PLC. I believe I need...
919
Hi All, Hope you guys are all well. Apologies for jumping onto this post but I am new here and this was the closest tread i found to what i...
2,185
Hi Experts. I need your help, I wanna communicate a MIcro850 with L19ER CompactLogix through Serial communication (Modbus RTU). I am using...
2,147
