![]() ![]() ![]() ![]() This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() ![]() Join Date: Oct 2020
Siemens S7/TIA v18: Is there a "first scan" in TIA portal?...
Hi, I want to initialise some tags on first scan only. As they are related to wall-clock time, I want to do the initialisation when the PLC first goes into RUN mode, rather than give the tag a 'start up' value in the datablock.
Is there a built-in tag that I can use for this? I *think* it might be %M0.0 but I'm not sure. Thanks |
#2 |
![]() ![]() Join Date: Sep 2010
Go to properties of the CPU.
Go to System and Clock memory Here you can enable System Memory bits. And then it is possible to select a MB. Then you have a bit for First scan. |
#3 |
For S7-1200/1500 you can activate the system bits. I think you can find them in the CPU properties under "system/clock bytes" or something to that effect. It is described in the dialog what are the merker addresses and their function.
In S7-300/400 you have to use OB100, OB101 and/or OB102.
__________________
Jesper ![]() NOTICE: JesperMP has passive-aggressive tendencies, can be impolite and may even use sarcasm ! Also: ᛁᚠ ᚢᚬᚢ ᚴᚬᚾ ᚱᛅᚬᛏ ᚦᛁᛋ ᚦᛅᚾ ᚢᚬᚢ ᚼᚬᚠᛅ ᚴᚬᛁᚾᛅᛏ ᛘᚢ ᚱᛅᛋᛒᛅᚴᛏ |
#4 | |
![]() ![]() Join Date: Jun 2013
Quote:
Couple options, in theory:
#5 |
Ah, cheers, all.
Sorted... |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
TIA Portal v18: WinCC: NEXT button valid only when user logs in... | Mas01 | LIVE PLC Questions And Answers | 7 | August 16th, 2023 04:46 AM |
TIA Portal v18: Does TIA Portal support "regular expressions"? | Mas01 | LIVE PLC Questions And Answers | 8 | August 9th, 2023 11:20 AM |
run Step 7 without TIA Portal | dmned64 | LIVE PLC Questions And Answers | 4 | June 7th, 2017 07:39 AM |
Siemens TIA Portal V13 Help | Nan | LIVE PLC Questions And Answers | 7 | May 18th, 2017 02:40 PM |
Siemens TIA Portal Step 7 V13 | lefeverj | LIVE PLC Questions And Answers | 0 | April 17th, 2016 03:47 PM |
