PLC GE-Fanuc can Online Edit Program while CPU Run Time ?
alpine
Dec 2011
Bangkok
51
Dear Everyone
I work with PLC GE-Fanuc. But I don't know that
"PLC GE-Fanuc (Series 90-30 and VersaMax) can Online Edit Programming
while CPU Runtime ?"
I used to work with PLC Allen-Bradley and I knonw that Allen-Bradley
can Online Edit Programming while CPU Run Time.
But for PLC GE-Fanuc, I don't know. Please inform me about Online Edit Programming of PLC GE-Fanuc
Thank You
The GE-Fanuc PLC line was sold to Emerson a few years ago.
The 90-30 and VersaMax do not have online editing, but you can download changes to the 90-30 while it is running. The VersaMax depends on the model and version of firmware as to whether it can download while running.
The newer Rx3i line has online editing.
If you want to save to flash memory, you will have to stop the PLC for all types.
Thank You dYoast
Before I post this question, I unintentionally online edit program by change instruction in Ladder (from ONDTH to TMR).
Then all ladders colour change to pink colour !
In my understand as your described ;
1. I can download edited program into CPU again ?
2. I must stop CPU before download ?
Do I understand correct ?
Yes, you can edit online if not making hardware configuration.
You will also need to verify how you are using the flash memory if your CPU supports it. It maybe configured to "always load from flash".
Why? If you edit online, it is not saved to the flash memory. You will have to stop the CPU then download and verify you are also downloading to FLASH Memory also.
Thank You Netnathan
As your described
If I would like to download to FLASH memory, I must stop CPU before downloading.
If I would not like to download to FLASH memory, No need to stop CPU !
And I have read about hardware of PLC GE-Fanuc ;
RAM memory need to use battery to store programming data when power turn off.
But FLASH memory no need to use battery.
It looks like we still got a few of these GE PLC around. A 90-30 and a Series one. Hoping someone familiar with these can help me with these...
4,440
Got an old machine with a IC610CPU104 CPU. A bit of research told me this is the same as DL305 so DirectSoft from AutomationDirect should work...
2,038
Our PLC output 7 opens a valve to move a cylinder rod. The output turns on every minute. The output is supposed to be ON for 10.56 seconds. But...
2,875
Need to find where to get VersaPro or Proficy software for the GE Fanuc 90-30 PLC.
2,530
Good afternoon all, hope everyone is doing well. Could someone explain the pic attached on the wrt.not instruction? To me, it looks the same as...
2,108
