CIP Generic Micrologix 1100 to Endress Flowmeter no communication.
can you post the N value (values? there may be two; hexadecimal would be best), and what the corresponding float value should be?
Protip: while Windows Snipping Tool and Microsoft Paint are fine, I love the inexpensive FastStone Capture tool for taking and annotating screenshots. Folks are much more likely to read your posts if they don't have to manipulate the images to read them.
I may be particularly grouchy about it because I have a stiff neck. :)
I admit I'm not familiar enough with CIP Generic Messaging in the MicroLogix 1100 Series B to say if there's a way to natively put data into a Float data file.
But the standard way to work around it is to use the Copy Word (CPW) instruction. That's a MicroLogix-specific instruction that can copy data bit-by-bit between Integer or Long data types and Float datatypes. You might have to swap bits or words, though I would expect an E+H device to use an A-B compatible data order.
+1; this is what I was hinting at.
I’ve decided I’m going to leave it as is for now. I’m way too busy to fiddle around with this thing. The operators don’t need the flow on the HMI anyway they can read it directly off the flowmeter. Next year when I go into this station to replace the pump control instead of tying it into this micrologic I’m just gonna replace it with a micro 820. I don’t want to jump through hoops just to get a Flowmeter to talk to something especially on a controller that’s going to be obsolete in a couple years anyway. But I really appreciate you guys for the input.
CIP Generic access to the Open Socket interface on the MicroLogix 1400 Hi guys, Looking for some help on getting 1 socket opened for a ethernet...
5,662
Hello, PLCS.net guys. I'm learning about MSG for TCP communication recently. I'm trying to use CIP Generic. And the main flow is like the one...
1,231
Hello, I am using a 1756-EN2T and tryin to communicate with a device that accepts ASCII string over ehternet usin UDP. Do packets sent using CIP...
1,797
Hi All - I am trying to communicate between a Micrologix 1100 and a Powerflex 525 via CIP MSG. There is a great Knowledgebase and TechNote...
3,994
Sorry if this is a beginner question, and I have looked at the manuals. Seems like a couple of tech notes would answer my question but I don't...
6,461
